Alignment specs for Slp spring/shock combo??
Old Jun 8, 2006 | 03:53 PM
touch109's Avatar
I know when you lower you have to realign what settings do i need with this setup and does it matter that im using an 18 in rim all round..
Old Jun 9, 2006 | 11:06 AM
touch109's Avatar
Re: Alignment specs for Slp spring/shock combo??
Talked to SLP and they said I should align it to stock specs.. but then i told him if i got bigger wheels then he didnt know... has anyone done this setup before slp spring/shock combo and then but on 18 in wheels.. what kind of alignment specs do i put it 2..
Old Jun 9, 2006 | 06:25 PM
BLDun's Avatar
I lowerd mine with Eibach sportlines and took the following measurements to the alignment shop and they aligned it accordingly. Haven't had any problems since.
1.0 degree camber; +4.0 degree caster; 0.1 degree toe-in
Hope it helps.
Old Jun 10, 2006 | 02:42 PM
touch109's Avatar
i think the sportlines lower the car almost 2 in... mine only lowers it about half an inch..... i dont know if there is a change in specs if i go from an 17 in to 18in... if there is not i'll stay with the factory specs slp told me 2.....
Old Jun 10, 2006 | 03:21 PM
BLDun's Avatar
I think you should be fine with the factory specs. A change in 1" rim size shouldn't make that much difference, I don't think.
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 17, 2015 08:31 AM
NewsBot
Sep 14, 2015 09:20 AM
tommalcolm
Sep 11, 2015 03:39 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
