Removing Turn Signal Lever
Old Jun 6, 2006 | 11:38 AM
ut's Avatar
ut
I've seen some posts suggesting that to remove the turn signal lever you just pull out on it. Do I just pull straight out away from the steering column? How much force is it going to take? Anything need to be disconnected first? This is a 93 Z28. Thanks!
Old Jun 6, 2006 | 12:35 PM
TraceZ's Avatar
Re: Removing Turn Signal Lever
Yes, just pull strait out on it.
If you have Cruise Control you will also need to unplug the CC wires.
Old Jun 6, 2006 | 01:12 PM
wrd1972's Avatar
TraceZ,
Can you please provide more detailed information on how this is done? What has to come off, where is the connector etc? I do have Cruise.
Does the handle disconnect from the other harnesses once it has been yanked out?
Old Jun 6, 2006 | 02:14 PM
There is a cover behind the lever. Slide it toward the dashboard for access to the connector. Disconnect the small connector and then you can pull the lever out.
Old Jun 6, 2006 | 02:25 PM
wrd1972's Avatar
Great, I was expecting to have to take the whole column apart. I want to replace this handle cause the lettering is all worn off.
Old Jun 6, 2006 | 02:39 PM
TraceZ's Avatar
I though only I was so **** that I would replace the lever for that cosmetic reason. I guess I'm not alone!
To keep it nice, i'm very carefull not to touch the lettering. I reach in further and touch it along its shank, instead of on the end.
I'm also very carefull about how I enter the car. I go out of my way to prevent any wear to the seat and sill. A little care and an interior will look new forever.
Old Jun 6, 2006 | 02:47 PM
wrd1972's Avatar
Yeah, but did you replace your door sill panels due to scratches?
I will replace anything that has normal wear if the cost is reasonable especially if I can sell the old stuff at auction or on the forum. You have to look hard to find anything even with slight wear in my car.
I know you replaced your leather seat covers a while back and that is the last thing that I really want to replace due to wear. BTW do they still look good and are they holding up well?
Old Jun 6, 2006 | 03:02 PM
TraceZ's Avatar
I've been hitting them with Zaino Leather in a Bottle.... They look better than new, not a mark on them! They smell pretty sweet, too. I found a good product for detailing the dash and console. It is called Meguiars Foaming interior protectant. It doesn't attract dust and dirt like products I've used in the past. I apply it, let it sit a few minutes and buff it off. The interior on my car really does look brand spanking showroom new, other than a couple very hard to notice scratches in the plastic trim.
Old Jun 6, 2006 | 03:05 PM
wrd1972's Avatar
Where do you get that mcguiers product at?
Old Jun 6, 2006 | 03:41 PM
TraceZ's Avatar
http://www.detailcity.com/meguiars-g...trim-foam.html
Old Jun 7, 2006 | 11:25 AM
ut's Avatar
ut
Thanks TraceZ and ShoeBox. I've replaced my interior switches with white lettering from the 94+ camaro. Turn signal lever with cruise is the only thing left. You guys have any recommendations on where to buy a 94+ lever?
Old Jun 7, 2006 | 11:13 PM
TraceZ's Avatar
Look on Shoebox's website. He has links to to a couple reasonable parts sources.
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
