oil pan 4
11-08-2002, 07:58 PM
If I used a hyd. roller lifter retro fit kit what cams would I use?
Normal flat taped hyd. cams or the hyd. roller cams?
Roller lifter retro fit, what cam?oil pan 4 11-08-2002, 07:58 PM If I used a hyd. roller lifter retro fit kit what cams would I use? Normal flat taped hyd. cams or the hyd. roller cams? Capn Pete 11-09-2002, 09:35 AM I believe you must run a roller cam with roller lifters, and a flat-tappet cam with flat-tappet lifters.........................I suppose you could try running roller lifters on a cam designed for flat-tappet lifters, but I don't think it's recommended --- use each part for its intended use - hence, roller with roller, non-roller with non-roller. | ||
