HELP !!!! Battery Relocation....I am going to burn my car very soon
Old Jun 4, 2006 | 12:21 AM
Schurters LT1's Avatar
Angry HELP !!!! Battery Relocation....I am going to burn my car very soon
OK i am just about to burn this CAR !!!!!
Put the battery in the back, to make room for the intercooler..
Ok this is what i have...
New red top- charger has been on it for the last few days to keep it up...
Power
00 welding cable FROM
bat to the kill switch
kill switch to the starter
starter to the power dis box on the fender ( this is 1 awg wire )
4 awg wire from the power box to alt..
Grounds
from bat to frame ( welded 3/8 bolt ) 1awg wire
from starter bolt to frame (welded bolt 3/8) ground strap
from bat to seat belt bolt 1 awg
from fender ground bolt to eng
eng to frame
Car would not start, the starter would click RAPIDLY. VERY fast.
i am out and done at this point....i don't no where to go with this.....
HELP ME
Old Jun 4, 2006 | 03:21 AM
mccullar_racing's Avatar
Re: HELP !!!! Battery Relocation....I am going to burn my car very soon
Are you sure your battery is good and putting out 12v. since you said above that your having to keep the charger on it.
Old Jun 4, 2006 | 04:29 AM
Angelis83LT's Avatar
only time i ever got rapid clicking was with an almost dead battery....
Old Jun 4, 2006 | 09:12 AM
Well, the bat is new and just putting a slow charge on it to keep it fresh...
Old Jun 4, 2006 | 10:58 AM
http://web.camaross.com/forums/showthread.php?t=453936
this helped as well
i did this as well
It was the small yellow/black wire from the Theft Deterrent Relay (TDR) to the BCM (body control module) which grounds the TDR through the BCM. So we just soldered on a "jumper" wire from the terminal at the TDR and grounded it to the factory grounding stud on the inside passenger door/closeout panel.
THe only diff this made was i could try and start the car with out the clutch...now i have to push the clutch in ....
liamcg97
Nov 25, 2019 05:55 PM
ddr698
Dec 31, 2014 09:16 AM
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
