Water Wetter?
Old Jun 3, 2006 | 08:33 AM
luis nunez's Avatar
Water Wetter?
When I use Water Wetter, do I have to bleed the cooling system if I put it straight to the radiator?
Old Jun 3, 2006 | 05:44 PM
pHEnomIC's Avatar
Re: Water Wetter?
If you are just adding it to the top of your system with a system that is already bled and filled sufficiently, you don't have to. So i don't think you have to worry about it.
If you messed with anything that could have gotten air in the system or you were running a low level, you would have to.
Old Jun 6, 2006 | 07:24 PM
fredmr39's Avatar
Re: Water Wetter?
no - but if temperatures look higher after, simply bleed
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 27, 2015 01:07 PM
