nitrojunky
05-28-2006, 09:58 AM
Also gonna sell my old stroker block. Everything looks good, also going to include the SCAT crank (3.75" stroke), GTP 6 cam (approximately a CC306 equivalent), GMPP Extreme Duty timing set. I pulled the motor due to a fluctuation in the oil pressure (would drop to ~20 psi under heavy acceleration then immediately return to normal), so you'll want to have a machine shop check out whatever you reuse. It was still running good when removed, but I didn't want to frag something a 100 miles down the road. It's been setting in my garage >3 years.
For local pickup in Pipe Creek texas only (NW of San Antonio).
PM me with an offer.
nitrojunky
05-28-2006, 06:21 PM
Regarding the inevitable questions about the oil pressure, here's what I know (which isn't a lot)...
I'm thinking it was likely a main or cam bearing, but it was >3 years ago. I missed a gear, then the next time I got into the throttle the problem started.
The oil pressure would drop from whatever it was normally (it's been a while, sorry) to about half its normal value, then it would immediately return to normal (this occurred over the course of about half of a second). This symptom was repeatable and always occurred near the same rpm, which happened to be near its peak torque rpm. I pulled it before anything drastic happened; car ran fine and made no weird noises and displayed no symptoms other than what the oil pressure gauge said; it still made full power, etc... I haven't looked at the cam, but the crank looked fine (no visible abrasion on the crank at the mains, etc), however the mains themselves showed a little brass, I believe (I'm no expert in that area, but I don't think they should've looked like they did).
The motor has been stored in a garage since it's been pulled.
It was the only time I'd missed a gear in the life of the motor, and supposedly it was built right :mad: (tho the crank was cheap, I guess).
I'll shoot some pics and get them up in about a few days (if it's not already sold).
nitrojunky
06-04-2006, 05:30 AM
Price is $100 for everything.
nitrojunky
06-04-2006, 10:19 PM
a couple of pics...
http://thumb2.webshots.com/t/48/49/2/2/98/2827202980091493322byQRbV_th.jpg (http://community.webshots.com/photo/2827202980091493322byQRbV)
http://thumb2.webshots.com/t/62/162/8/64/94/2351864940091493322woynqo_th.jpg (http://community.webshots.com/photo/2351864940091493322woynqo)
http://thumb2.webshots.com/t/36/37/0/64/95/2144064950091493322TGoGLk_th.jpg (http://community.webshots.com/photo/2144064950091493322TGoGLk)
I'll also include the main caps with their ARP bolts.
http://thumb2.webshots.com/t/60/160/6/77/67/2279677670091493322yptika_th.jpg (http://community.webshots.com/photo/2279677670091493322yptika)
nitrojunky
06-07-2006, 10:48 PM
intrested.
Shoot me a pm.
edit: extra pics.
http://thumb2.webshots.com/t/62/62/7/66/61/2194766610091493322fYCowQ_th.jpg (http://community.webshots.com/photo/2194766610091493322fYCowQ) http://thumb2.webshots.com/t/30/31/5/98/98/2390598980091493322NduvFe_th.jpg (http://community.webshots.com/photo/2390598980091493322NduvFe)
http://thumb2.webshots.com/t/61/161/6/87/77/2445687770091493322rmdAjz_th.jpg (http://community.webshots.com/photo/2445687770091493322rmdAjz) http://thumb2.webshots.com/t/36/36/1/64/16/2252164160091493322IVNRsd_th.jpg (http://community.webshots.com/photo/2252164160091493322IVNRsd)
http://thumb2.webshots.com/t/40/41/7/96/60/2466796600091493322ssuQan_th.jpg (http://community.webshots.com/photo/2466796600091493322ssuQan) http://thumb2.webshots.com/t/60/60/0/93/55/2272093550091493322NGXLwV_th.jpg (http://community.webshots.com/photo/2272093550091493322NGXLwV)
http://thumb2.webshots.com/t/59/59/2/53/67/2369253670091493322YNBwMn_th.jpg (http://community.webshots.com/photo/2369253670091493322YNBwMn)
