4th Gen. Coolant Capacity?
19z28camaro02
05-19-2006, 12:29 PM
How coolant SHOULD a 4th gen LT1 hold?(radiator and resevior)
MARKTHOMASBRAND
05-19-2006, 01:10 PM
Hi there,
According to my hand-book,cars with manual transmission hold 14.5L of coolant and autos hold 14.3L of coolant.This capacity is for the entire system,ie the block,radiator,reservoir,hoses etc.
Hope this helps,Mark.
Injuneer
05-19-2006, 02:35 PM
For non-metric units, divide the numbers above by 3.78, or look in the Owner's Manual. If you don't have one, Shoebox has a link to an online copy.
http://shbox.com/pdf/manuals.html
shoebox
05-19-2006, 10:45 PM
...or elsewhere on my site it says:
LT1 coolant capacities for the 4th gen F-body:
With Manual Transmission - 15.3 quarts (14.5 L)
With Automatic Transmission - 15.1 quarts (14.3 L)
Dave89IROC
05-21-2006, 07:20 PM
To the best that I could, I put some epoxy on the crack in my tank. It doesn't leak AS BAD as before, but it still does. Should do a more thorough job with the epoxy/take that off and use JB weld/ or what?
personally, I'd replace the rad
fredmr39
05-21-2006, 07:24 PM
huh?...what does that have to do with this thread, and further, Rob's post that you quoted??
I don't even know what "tank" you are talking about. The coolant resevoir? If that's the case, I would just buy a new one. Otherwise, define "tank," and possibly start a new thread.
moparman
I think you'll end up replacing the radiator.
Jazsun
05-21-2006, 10:16 PM
Its two of those coolant jugs you buy at autozone.
Injuneer
05-22-2006, 12:03 AM
Why are you hijacking someone else's thread. If you have a problem, and need help, start your own thread. Really discourteous.
wdtiger
05-22-2006, 03:30 AM
quite possible one of the best hijackings i've ever witnessed.
fredmr39
05-22-2006, 08:02 PM
And we really need a dozen people telling this guy the capacities are:
Once that information is given, I don't see a problem with asking a very closely related COOLANT question. :o
That's not very closely related AT ALL. There are hundreds of problems that could deal with cooling systems. A very closely related question would be something like "does anybody happen to have those numbers in gallons?" -even though I believe the conversion was already given.
