will this fit?
2strokefreak
05-17-2006, 01:09 PM
http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10001&catalogId=10002&catalogIdentifier=&categoryId=27863&parentCategoryId=10355
will that fit on my 305 without major modifying.
teke184
05-17-2006, 01:28 PM
no...
looks to me like it designed for dual 4barrel carbs....
not to mention you'd have to cut a hole in your hood.
DontMixWithRice
05-17-2006, 01:38 PM
hahahahahahahhahahaha
TraceZ
05-17-2006, 02:17 PM
http://www.jegs.com/images/photos/55550050.jpg
OMG, please tell me you are kidding.
:lol:
2strokefreak
05-17-2006, 02:56 PM
what i mean "you oh so kind forum people" is when i order it will it let me tell them which engine model i have and send me the one i need?
TraceZ
05-17-2006, 03:13 PM
Sorry, I did not intend to be mean to you, but I saw humor in it. ;)
Here is a respectfull answer:
That scoop you are looking at is for a dual carb setup, that means two carbeurators on a twin 4bbl intake manifold.
To run that scoop, you will need to
1) cut a hole in your hood
2) remove your intake manifold
3) install a twin 4bbl manifold
4) install two 4bbl carbs, linkage, fuel lines, pressure regualtor, etc.
5) install a non computerized distributor/ignition system
6) install the big-ass scoop in the picture.
Q: Do they make a scoop like that that will bolt directly onto your car?
A: Not without cutting a big hole in your hood.
They do make single carb scoops that could bolt over your existing throttle body, but like I said it will require a hole in the hood.
2strokefreak
05-17-2006, 03:55 PM
do you know of any scoops like that that my motor can use without major moddifying. and i dont care about a hole in my hood. my dad runs pick a part i can get alot for cheep.
EnerjetF67
05-17-2006, 04:01 PM
That thing would be SERIOUSLY RETARDED on ANY 305 !
All SHOW and absolutely ZERO go !
Any 2x4bbl setup on a 305 is at best a serious case of unusable induction capacity, and at worst a serious WASTE of gasoline that could be used to produce worthwhile power in a REASONABLE displacement Chevy V8.
IMHO, the 305 is the one of the absolute worst Chevy V8's ever sold....most of them make a lowly 307 seem like a real V8.
You should concentrate on getting a real engine that makes power, not bolting a Mega-$$$ huge scoop onto an engine that will do virtually NOTHING to improve the performance. These belong on a tunnel-rammed high-hp Big-Block, PERIOD !
TraceZ
05-17-2006, 04:03 PM
Your throttle body uses a standard size openning. A scoop for any single 4bbl carb will fit. Summit or Jeg's .... Either one will have them.
One problem I see... those scoops are designed to be used without any air filter. Not a good idea on the street. Also, i'm not sure if it is legal to have a air intake sticking up out of your hood above a certain height.
Here is a picture of a scoop for a single carb. This will fit over your throttle body without major modification. Keep in mind, no airfilter = bad for motor.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MRG%2D6651&N=4294925239+4294839057+4294887855+115&autoview=sku
http://static.summitracing.com/global/images/prod/large/mrg-6651.jpg
teke184
05-17-2006, 06:58 PM
alright man...
before you go and put a hood scoop on a 200hp V8...
go through and flush your blinker fluid...synthetic if you can afford it...and replace and grease your muffler bearings...
seriously...
EnerjetF67
05-17-2006, 07:53 PM
teke:
You forgot to ask him to add a duocabulator valve and an ELECTRIC turbocharger ! :death: :death: :death: :D
teke184
05-17-2006, 08:34 PM
eh...forget those electric turbos....
it's all about the turbinator...
up to 30% increase in hp/torque and fuel economy....
**** thats like adding nearly 120hp to my cam only LS1:cool:
deputydough
05-17-2006, 10:19 PM
according to the listing, it will fit most 2 bbl and 4 bbl applications. it also comes with air cleaner. not that i'm agreeing, just making an observation.;)
