(LT1) Header install tips
Cha0s97
05-15-2006, 08:28 PM
Im considering installing a set of BBK mid length headers on my 97 Z28 with a M6 this weekend. Wondering if anyone has any install tricks or tips or maybe a walkthrough? Ive installed shorty headers on a third get before and had to remove a valve cover and alternator to get them to slide in. Also, any tips to get the manifolds off a little easier? Any help is much appreciated,
Thanks,
Danny :D
bringBackCamaro
05-15-2006, 08:51 PM
take your time
make sure you have penetrating oil and anti-sieze ready
Be careful to take the dipstick out, you dont want to break it off,
mine went into the pan about 6 inches, so its a lot of pulling
I put some pliars on the bracket and twisted while pulling and it came out quick
Put it in the freezer to put it back in, it works wonders
for the steering linkage, use a screwdriver to pry it out, and possibly a hammer to help it go back in
Gap your spark plugs the night before, you dont want to be doing precision work when your all tired and greasy
Good luck
Spitfire557
05-15-2006, 09:03 PM
I took the alternator, the dipstick, and the starter off to install my mid's. They will go in from underneath, not up top. Just make sure you soak the stock manifold bolts down with penetrating oil real good the night before. It should go smooth, mine did, not nearly as bad as everybody made it out to be.
94zgreenmachine
05-15-2006, 09:09 PM
patience, the most important of all. When things feel like they are getting bad and the attitude starts to go south, just walk away and take a little break. These cars can be very frustrating to work on till you get the "order" of how things are done. It is worth the hassle, trust me.
snakeatinZ
05-15-2006, 09:18 PM
extend and relocate the wires that run down the pass. side inner fender well. They will burn if you dont causing your car to not start. Two of the wires go to the starter.
Steve
94jetpilot
01-18-2007, 11:09 AM
anyone done this to a automatic z? if so what kind of time frame am i looking at?
2000GTP
01-18-2007, 11:35 AM
It depends on your skill level and how smoothly the job goes... you can be done in a day or it can take a few days.
94jetpilot
01-18-2007, 11:50 AM
theyre on their way now, but i found a shop here locally thats doin it for me for 300 bucks, a performance shop that has done these time and time again,what kind of wires would be recommended? any help would be appreciated.
94jetpilot
01-18-2007, 11:51 AM
new to this site,...but old to my share of experiences with my z., gone through it all!!!
2000GTP
01-18-2007, 11:52 AM
300 bucks is a good deal for a header install. What kind of headers do you have? If you have long tubes, then I would suggest going with an over-the-valve cover wire setup. If doing shorties or mids, then I would stick with the stock routing and go with an MSD or Taylor replacement wire set.
97WS6SCharged
01-18-2007, 12:50 PM
Buy a good set of gaskets and bolts instead of using the paper gaskets that come with the headers. :)
Chris 96 WS6
01-18-2007, 01:41 PM
Here's a header install article that will give you a few tips/tricks. I wrote it about 6 yrs ago. http://lt1howto.com/articles/flpinstall.htm
Critter
01-18-2007, 01:45 PM
use copper gaskets!!!!!! summit sells them for 25 bucks IT IS WORTH IT!
TobyZ28
01-18-2007, 02:42 PM
Mechanix gloves!
2tight
01-18-2007, 03:57 PM
Hey what part of Texas you in? if you are around DFW please tell me who is doing your Header install.
Lookn4MySS
01-18-2007, 04:05 PM
Prepare to bust your knuckles up and use air tools. :lol:
JAG05
01-18-2007, 04:16 PM
Can you run the stock size wires over the value cover or do you need longer wires to do this?
2tight
01-18-2007, 04:20 PM
I think you need longer one's here is a link take a look
http://www.thunderracing.com/catalog/?action=vshop&vid=4&pcid=104
camarozz95
01-18-2007, 04:22 PM
I actually bought the Taylor Over the valve cover kit and it ended up being back ordered so when I did the install I just used the stock wires with stock routing and believe it or not have not had a problem none of the wires even come close to the headers.
I still do plan on putting the new wires in at some point just haven't had the time since school restarted
2000GTP
01-18-2007, 04:23 PM
Either will work, however, if you are going to use the stock routing setup, you may have to use come cable ties to secure some of the wires away from the header primaries.
2tight
01-18-2007, 04:26 PM
Would those be plastic cable ties?
2000GTP
01-18-2007, 04:29 PM
Yes.
Critter
01-18-2007, 06:07 PM
where you live?
94jetpilot
01-21-2007, 01:10 AM
here in san antonio texas, a place called alamo performance, talk to roy in installation,does them all the time i hear, real good at it! hope it helps.
