abs 3vs. 4 Channel
radarb8
05-13-2006, 11:03 AM
Has any one put a 4 channel abs rearend in a 3 channel car by just tapping in to the abs sensor at the wheel on the 4 channel ?
Silver
05-20-2006, 07:32 PM
have you learned anything yet? i have a 4ch rearend i picked up for my 3 ch car and i'm a bit sad.
radarb8
05-20-2006, 10:45 PM
Not yet . I guess it must not be something too many pepole have tried to do
Silver
05-21-2006, 01:27 AM
well i read where you can take one sensor from a 4 ch and run it to the single input for a 3 ch. also, found the abs inop light delete here: http://www.bfranker.badz28.com/fbody/abslight.htm
my question now is if i leave the rear unplugged altogether does the front abs still work...
seawolf06
02-13-2007, 12:35 PM
I know this is old, but I want to know this too. I was told no.
respectirocz
02-13-2007, 01:10 PM
i believe all abs systems have a failsafe where if the abs light is on, the abs system is disabled, there is no partial abs, or front only abs
Zeetwentyfate
02-13-2007, 01:48 PM
yeah you cant make a 4ch and 3 ch work together the speed of the rings the sensor will be different and there fore will not work.
seawolf06
02-13-2007, 02:38 PM
Ok, I just wanted to see if anyone had figured out a way.
