jons70gto
05-11-2006, 10:22 PM
Whats the best wat to tell if a 69 camaro is an ss or not if it doesnt have the original motor??? trim tag???
1969 camaro ssjons70gto 05-11-2006, 10:22 PM Whats the best wat to tell if a 69 camaro is an ss or not if it doesnt have the original motor??? trim tag??? XcYZ 05-12-2006, 09:52 AM Camaros.org is a good resource. Here's the section on 69's. http://www.camaros.org/diffs69.shtml VETTEpwrdZ28 05-16-2006, 03:35 PM the answer is, there is no way, unless you have the build sheet, or other documents, all you can do is see what options it has, and then the the chances are good, it might have been an ss, but like i said, there is no way to prove it 94B&RZ-28 05-18-2006, 12:36 AM for a 69 you will have a X66 code on the data plate. Guarenteed way to tell. Steve69SS396 05-18-2006, 01:07 AM for a 69 you will have a X66 code on the data plate. Guarenteed way to tell. The X codes were not used at all of the assembly plants. 94B&RZ-28 05-18-2006, 07:46 PM thats right, it was only van nyes right? | ||
