Best sway bars and sizes
mook99TA
05-11-2006, 08:59 PM
I am looking at the spohn front and rear sway bars. The car is for a dd and occaisional track time both strip and autox. I know I want solid but not really sure what size's and what brand are the best.
teke184
05-11-2006, 11:41 PM
hard to go wrong with the 32/21mm bars from BMR
it's a good all around setup...made AMAZING improvements on my cars handling...on both my 96 and now my 99
Bud M
05-12-2006, 01:49 AM
Not sure why you want solid bars, I'd get Strano's 35/22 bars, 32 is a bit small on the front and Spohn's 32/22 combo will be tailhappy. Strano's will be lighter too. I've had the BMR bars and they are not bad but the Strano front bar is better IMO.
5.0THIS
05-12-2006, 06:49 AM
I guess he wants heavier parts that arent hardly any stiffer :think:
NOSCaMaRo
05-12-2006, 11:48 AM
Call Sam Strano, he will be happy to explain what is best and you need, esp. since it seems you are doing some AutoX
mook99TA
05-12-2006, 03:37 PM
what do you mean by tail happy?
stereomandan
05-12-2006, 08:16 PM
If hollow, go with the Strano 35mm front and 22mm rear, if solid then go with the 35mm Suspension Techniques bar and 1LE 21mm rear bar.
I have the two solid bars mentioned and it made an incredible difference in handling. By far the best handling mod I've done.
Dan
Bud M
05-12-2006, 10:15 PM
A stiffer rear roll bar will give the inside rear tire less grip, making the rear slide more easily in turns. The 32/22 combo will make the anti roll balance stiffer at the rear. The optimum setup seems to be 35/21 solid or 22 hollow, assuming wider 17" wheels. With stock 16" wheels, a 19 mm rear bar might be better.
mook99TA
05-13-2006, 10:00 AM
thanks
