LPE driveshaft
Old May 10, 2006 | 04:15 PM
green.Z's Avatar
LPE driveshaft
Anyone have experience with the Lingenfelter aluminum driveshaft?
I still have some vibration at speed on the interstate. My driveshaft was loose at the rearend, so I had it rebuilt with 373 gears and new bearings. I then discovered my driveshaft was bent (probably what caused the pinion bearings to go out), so I bought the LPE driveshaft. Then I found that my tires were out of round and they were almost to the wear bars anyway, so I replaced them. It is much better than before, but there is still some vibration.
The LPE driveshaft is balanced with weights, but it also does not spin true. When I'm under the car with the driveshaft turning, it is out of round. Or, more accurately, it looks as though the shaft center does not match the center of the yokes. Could this be the problem? Anyone else notice this with their driveshaft?
I also rotated tires front to back, with no difference. The vibration is through the seats, not the steering wheel.
Old May 13, 2006 | 11:38 PM
Bud M's Avatar
Re: LPE driveshaft
I have no problems with my LPE ds. If you really suspect its not right, you should be able to get it checked I guess, but I'm not sure who could do that.
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
