rwjohnson06
05-04-2006, 01:27 PM
I just have just installed a power window kit in my 1980 Camaro, everything works fine when all of the bolts on the door a loosened (the 7 on top, just inside the window) But when i tighten all of them back up and return the pads to their original position, it works but bogs horribly starting and then completely stops about midway then i have to assist it by pulling up on the window by hand. Iv'e tried greesing the tracks and even realigning the tracks to try and illiminate the bind. The circuit i'm sure is fine its on a 30 amp circuit directly from the fuse block instead of using the inline fuse provided in the kit.
