Small shot?
Z-RATED94
05-04-2006, 03:20 AM
Any idea on how much of a gain a small shot would help in the 1/4 mile? Some kits start out as low as 35 to 50 HP, correct? I'm looking for results anyone might have for a car that already runs low 12's, high 11's. Also, does a puny shot like that help the 60ft. much?
MeanGreen97Z
05-04-2006, 11:20 AM
If you are having trouble with traction already in the 60' range then a small shot will make it worse. If you are hooking up well and have the tires and suspension to do it then a small shot in the 60' will help out. A 50 shot will give you between .3 and .6 seconds off your 1/4 time. You might get 3-5 mph from it.
Z-RATED94
05-04-2006, 11:40 AM
MeanGreen, thanks for the reply. Traction's really not a problem and I have a set of ETs that I will be using this year. I plan on not spraying thru the shifts (stock :think: trans) even with a small shot and if I bump up the HP level maybe I'll lock out 1st gear.
Joe B
05-04-2006, 03:50 PM
Joe B
05-04-2006, 03:51 PM
[QUOTE=Z-RATED94]Any idea on how much of a gain a small shot would help in the 1/4 mile? Some kits start out as low as 35 to 50 HP, correct? I'm looking for results anyone might have for a car that already runs low 12's, high 11's. Also, does a puny shot like that help the 60ft. much? .................................................. .................................................. .......... with the mods in my sig, The first time at the track I ran a best of 11.84 @ 119, 1.70 60 FT(all motor).........and with just the 75 shot, It went 11.19 @ 125.7, 1.65 60 FT.....this was spraying right from first gear all the way thru the shifts....gonna try the 125 shot (to the wheels) next time out:cool:.....this is with a fairly small daily driver cam in the mid 220's @ 50 at around .600 lift.........:cool:
Joe B
Z-RATED94
05-04-2006, 06:28 PM
Thanks Joe. It looks like are choice of parts are similar to one another. ;)
camaro81
05-04-2006, 07:34 PM
I tried spraying a 40-50hp shot last weekend in Maryland, it gave me a .07 increase in my '60 and actually put a few inches of air under the left front tire :D I went from a 1.72 to a 1.64 60' and it created that "stall wall" problem that sent the transmission into limp mode so I didn't get a clean pass.
If nothin else, the small shot of nitrous would put a bigger grin on your face when you launched :D
Joe B
05-05-2006, 12:39 AM
Yea, I diddn't even realize that:cool: ......have you been to the track with your current set-up yet?
Z-RATED94
05-06-2006, 05:35 AM
Twice last year. 1st time a 13.10 @ 105mph. Horrible 60 ft. on a hot day with many issues. Next time out a 12.64 @ 109mph with a 1.80 60ft. on another very hot day with half the problems worked out. Looking forward to this year. Very very low 12's should not be a problem. After that a small shot of juice will be in order. It's mid to high 11's or we step it up a notch and go for high 10's. No more fooling around. :D
