always faster
05-02-2006, 10:05 PM
Ok i got a little problem that seem to be coming from the power steering pump.
When the car is cold and i turn the wheel full left or right , everything is perfect,no sound.
But..when the car gets hot,in normal temp range if i turn the wheel full right or left the pump make a howling noise.
So what should i do? Replace the ps fluid with brand new one or i should replace the pump right away?
How hard is it to change this part?
Thank you ;)
Thank you ;)
