Stock tach is off which way?
Old May 1, 2006 | 01:37 PM
Z-RATED94's Avatar
Everyone says the factory tachs are off quite a bit. I can't remember which way. I'm going to quess and say they are on the slow side, is this correct? At 6,000 rpm how far off is it? Thanks.
Old May 1, 2006 | 04:02 PM
Dave '97 Z28 M6's Avatar
Re: Stock tach is off which way?
I know that right now my idle is set to 875 (confirmed by Datamaster) and the tach shows idle at ~1000. So, at least at idle, my tach reads fast.
Old May 1, 2006 | 04:12 PM
StephenDeli22's Avatar
At idle tach shows 200 more thanis and while driving it shows 100 rpm more than it is.
Old May 1, 2006 | 10:21 PM
TraceZ's Avatar
Mine is 200 high.
Old May 2, 2006 | 08:12 AM
Z-RATED94's Avatar
Well, as usual I guessed the wrong way. The good news is, I need to have my shift points changed. I'm probably off by at least 3 to 4 hundred rpm. I hope it helps my times. Thanks guys.
Old May 2, 2006 | 08:38 AM
JakeRobb's Avatar
Super Moderator
They vary. Mine is within 50 rpm at all times.
Old May 2, 2006 | 08:42 AM
Z-RATED94's Avatar
That's why I need an aftermarket tach installed to go along with the other gauges I've been sitting on. This summer is for fine tuning what I have before raising the bar.
Old May 2, 2006 | 09:28 AM
YARDofSTUF's Avatar
Why are they so off and why do the aftermarket ones read accurately? Is it just a cheap tach or do they have different methods to read the rpms?
Old May 2, 2006 | 09:56 AM
TraceZ's Avatar
I dont know why they are so often off, but I plan to correct mine by pulling the needle off and sticking it back on in the right place. I have a scanner I can use to verify its accuracy afterwards, and assist me in gettting it on correctly.
mr28
Apr 20, 2016 05:44 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
mr28
Nov 23, 2014 11:11 AM
