will this work?
shortman1124
04-27-2006, 10:46 PM
have a 2002 camaro its a ttop and im looking into getiing a set of c6 rims. the sizes are 19x10 and 18x8.5. will these rims fit? will i have to get any spacers or anything?
ibanez6rg
04-27-2006, 11:43 PM
The fronts will fit fine and the backs might need a little work to get them to fit. Other than that you'll be OK. Stay away from spacers though.
Injuneer
04-28-2006, 11:06 AM
Factory wheels or aftermarket replicas? Do you know the offset or backspace of each wheel?
shortman1124
04-28-2006, 04:22 PM
they are oem rims. they were on a corvette though. what do you mean by a little work? will i have to modify anything?
Injuneer
04-29-2006, 11:34 AM
This is what Skulte Designs shows as the stock C6 wheel dimensions:
C6 Corvette 18x8.5 front (GM 9594351) 58mm offset; 6.53" backspace
C6 Corvette 19x10 rear (GM 9594353) 79mm offset; 8.11" backspace
You will need a spacer in the back.
Look at the Wheel and Tire FAQ, stickied at the top of the topics listing. Open the FAQ and go to the very bottom of the thread. There is a detailed explanation of what you need to do to put those wheels on your car.
shortman1124
04-29-2006, 09:21 PM
thanks
