batmb13
04-25-2006, 06:36 PM
i have a 350 with a 750 holley carb on it. when i gun it it misfires past 4500 rpms and then as soon as i let off it backfires. is this to lean or to rich of a mixture.
help with misfiringbatmb13 04-25-2006, 06:36 PM i have a 350 with a 750 holley carb on it. when i gun it it misfires past 4500 rpms and then as soon as i let off it backfires. is this to lean or to rich of a mixture. spinout 04-25-2006, 07:17 PM first do you have an exaust leak anywhere second how about some info on the motor could be a number of things high k motor it could be cam exaust leak valve adjustment spark plugs, wires,cap and rotor coil ??? batmb13 04-25-2006, 07:40 PM i do have an exhuast leak. my headers do not seat well and there is a little leak on the drivers side. 84firebird 04-27-2006, 05:55 PM what i'd look at is timing, shoot a timing light at it and see what it looks like. and next, the coil might be worthless stale 05-02-2006, 11:45 AM That 750 Holley, unless it's toast, should easily feed that 350 up to the redline. Check the coil and wires. | ||
