lt1/lt4 parts in dfw
Old Apr 25, 2006 | 12:07 AM
Daniel6718's Avatar
New Stuff
ac condensor 93-97...45
stock monsoon amp from 2001 z28...20
ls1 rear brake calipers, rotors, emergency brake backing plates...160
dark grey set of floor mats front and back...25(PENDING)
one perfect drivers side ttop shade... 10obo
one good 1 wire front o2 censor ....5obo
6 speed shifter...short throw now" its been cut about inch and half, pm me for pics...15obo
8 lt1 pistons and rods... no spun bearings known...30obo
crank for lt1 with 1 spun main and spun rod #8...might be trash 15
have passenger side block motor mount...5
white leather rear seats...need tlc look decent...50
rear seatbelts and brackets dark grey...15
lt1 map sensors 1 brand new 1 low miles ...5
stock lt1 cam...15
stock lt1 cam gear...5
stock lt1 valvetrain(spring reatianers locks studs valves)...15
stock air pump...15
set of lt1 front brake pads almost new...20
Parts needed..
rear lt1 backing plates non tcs
non tcs wire harness from body to rear end...
wire harness for passenger front caliper...
oil sending unit on back/top of block
motor mounts mount to k member on passenger side (pending)
ac delete pulley
everything is make offer...i need this stuff gone
daniel
Old Apr 25, 2006 | 05:31 AM
MeanGreen97Z's Avatar
Re: lt1/lt4 parts in dfw
Install my headers and pacesetter y pipe and i'll give you some manifolds with y pipe and a flowmaster catback.
Old Apr 25, 2006 | 05:38 PM
Crap im trying to get this stuff installed before I get home from Iraq..... haha
Old Apr 26, 2006 | 08:34 PM
NightTrain66's Avatar
If the heads are NOT 561 castings, I'll take them.
You can even strip the springs off of them and sell with the Hot Cam since i do not need them.
Lloyd
Old Apr 27, 2006 | 08:26 AM
gogogadget's Avatar
"A4 console insert"
Is this the plastic square insert that goes over/around the shifter?
Old May 9, 2006 | 10:35 AM
95 N2OT/A's Avatar
so now you take $90 for the fans and radiator
are you still in need of the hood i'll do $30 plus the hood and trade you lines for the radiator and fans
if interested get back with me
thanks
robbie
Old May 16, 2006 | 12:13 AM
WhiteThunderZ28's Avatar
How much for the AC Delete Pulley set up?
Old May 20, 2006 | 08:26 PM
Daniel6718's Avatar
new stuff for sale new stuff needed
novaiiman
May 15, 2016 11:36 AM
armedtrigger
Feb 13, 2015 08:20 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
