Can someone explain strength of gears 4.10 vs. 3.9 etc
I have heard a bunch of random things on here about some gears being stronger because of the amount of teeth. I have also heard differing opinions like some saying 3.73s are stronger then 4.10s and vice-versa. Going off of this, how would a set of 3.90s in the 10 bolt compare? Yeah, I know they are all weak, but which is inherently the strongest?
Re: Can someone explain strength of gears 4.10 vs. 3.9 etc
The higher the gear ratio, the more teeth will be on the ring gear. Since the gears are the same diameter, the teeth have to be thinner to fit more teeth. Therefore thinner teeth = reduced strength given that the gears are made from the same metal. Not sure if 3.90's are made for the 10 bolt.
Originally Posted by blackrat
... so I should be fine. Thanks
Ben T.
Well, I mean I know it's going to snap like a twig if I drop the hammer on it, but I'm going to be changing some things around (lighter flywheel, LPW girdle) plus I'm not a dragger. The reason I want those gears is because they will allow me to ride out all of fourth in the straight at a nearby track. Light street duty is all it's going to be seeing too (3000 rpm slips on streets) Still, going by that rule of thumb it should be somewhat stronger then 4.10s, and those are usually what's recommended to people.
Now after all this I better knock on wood ( :knock on wood: ) or else my next post be asking you how your 8.8 set up is doing, cause I need one.
Apr 16, 2015 09:57 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
