Emissions question
David94TA
04-23-2006, 09:33 PM
Any of you guys passing emissions with larger injectors? I have been having problems passing with my current set up (see sig). The CC305 cam is on a 112 lsa. I am in the process of changing to a blower cam and am installing a set of Kooks headers with their catted Y-pipe. I considered changing to smaller injectors just for the emissions test, but doing that on a yearly basis would be a pain. I keep failing on the hydrocarbons. 220ppm is the limit and with my current set up detuned and with some fuel additive I got to 280 the last time.
OBE1 95Z28
04-23-2006, 10:49 PM
My friend's 95 Z28, 383, 224/236/114 cam, AFR heads and blower passed smog no problem here in CA.
jerminator96
04-23-2006, 11:19 PM
He passed in CA???:eek:
Good thing that I'm exempt here with my 94:D
And even if I wasn't, I know the right people;)
94 NO TOP Z
04-25-2006, 12:05 AM
With my 72lb inj I never can get it to idle any leaner than 12.5 AFR and always fail... I think I had 500ppm HC's. Swap in the stock injectors and tune and it blew a 50 PPM HC. I've had to do it the last two years.
David94TA
04-25-2006, 07:50 AM
That's pretty much the same problem that I've been having. Guess I'll have to do the same and swap injectors for the test.
Flip94ta
04-28-2006, 02:09 AM
Using 94 NO TOP Z's tunes I have passed with 50's three years in a row. I think the key is changing the fan settings back to stock, I think the fuel burns off in the headers.
David94TA
04-28-2006, 08:23 AM
Flip94TA: What size injectors are you using?
Flip94ta
04-28-2006, 12:38 PM
50's, I remember you have a hard time last year also.
David94TA
04-28-2006, 03:40 PM
I just looked at your last post and you already answered my question. I don't know how I didn't see that. Duh. You are right. Last year was the first year of testing and I tried to get through 5 times and never passed, so I just gave up for a while until I could get these other changes made. I told my tuner that we have to get it through this year, so we are pulling out all the stops. I'll pass your info on to my tuner.
AlexA
04-28-2006, 08:21 PM
Are you guys running hi or low Z injectors?
I'm assuming "94 NO TOP Z" 's injectors are low Z. You can't get better than 12.5:1 AFR at idle? Jeez...
-Alex
Flip94ta
04-30-2006, 03:19 PM
94 NO TOP knows more about tuning than me, but I do remember that the injectors are set at 42.67lbs in the tune, they are supposed to be msd 50's but I bought them used and never ran the model number on them, it doesn't lean out so I am assuming that they are correct and the car just runs better at the setting. I think the AFR was 12.2 on the dyno.
I would just try a stock tune with the injector size corrected and idle at 850-900. If you fail HC, it should only be in the 250-500 range, adding about 5-10 bottles of .99 cent drygas will lower the HC more.
What kind of numbers did you see last time?
I been wondering if the ethnol changeover in pump gas will also make it easier to pass on HC.
94 NO TOP Z
05-01-2006, 12:23 PM
I am running the low-Z 72's. I played with the programming a lot but, have never been able to idle at the correct AFR. Ever since I have installed them the O2's just don't move at idle and the BLMS never move. Could be something simple.
AlexA
05-01-2006, 02:32 PM
I assume this is closed loop? The injector offsets are set and everything?
I'm just hoping I won't have issue idling at 14.7:1 with large low-Z injectors. Trying to understand if this is a mechanical limitation (running high fuel pressure or/and the injectors are simply to large) or if it's a programming issue.
-Alex
