Plugs, wires, and ignition for N2O.
Jeremy95TA
04-23-2006, 07:14 PM
My parents are buying me a nitrous kit for graduation. Its time to put that 9" rear and clutch to good use by spraying out of the hole. Soon I will be installing the usual bolt-ons (CAI, LT's, Y-pipe) and then getting the car tuned for N20. While I am doing the LT's, I figure it would be a good idea to upgrade to nitrous friendly plugs and wires.
First off, I hear people mention OTVC wires and I have no idea what the hell that is, so if someone could please explain that I would appreciate it. Second, since I will be running nitrous I will need a colder plug (at least thats what I hear tell). I know that a common plug for the LT1 are NGK TR55's. I also hear talk about copper and irridium plugs as well (Like I know what the differences/benefits/disadvanteges of those are ). Some people run AC Delco plugs and something else as well.
If I'm not mistaken the most common sizes of wires a 8, 8.5, and 9mm wires. Which should I get and why? Which brands also? I know that the common ones are MSD, Taylor, and Accel. I also know that some people install plugs and wires and then burn holes in their wires in 2 days, I'd like to avoid that (obviously).
Will I need and ignition like the MSD 6AL or something along those lines? I believe that I can run nitrous without an ignition, but would it be wise to upgrade?
Finally, it is a long ways away but the eventual plan is to pull the motor, forge it, and spray the piss out of it, so if I can get parts now that will be good then it will help.
Mike Comp T/A #57
04-23-2006, 07:41 PM
OTVC stands for over the valve cover.
I use NGK TR6 plugs.
You will need a MSD6A ignition box.
I use MSD 8.5 mm wires.
Hawk
04-23-2006, 08:21 PM
also if you plan on juicing more then 100hp shot, go with an ignition with build in timing retard that can be triggered when your spraying.
Brian
nfa
04-23-2006, 08:37 PM
The mallory 685 is a nice unit that offers timing retard and a window switch all in one box.
2000GTP
04-24-2006, 04:59 PM
Exactly, a very good bang for the buck box. I would also go with the NGK TR-6 plugs as mentioned above. A bottle heater and fuel pressure safety switch would also be good ideas as well.
