max psi?
blahster
04-20-2006, 03:37 PM
I am contemplating dropping an STS turbo on my Z...MAYBE...have not decided yet.
I have a 355 with forged pistons...stock rods...stock crank...and LE3 heads...and LE3 cam...i estimate about 10.6cr....what would the most boost i could run safely be? if recommended at all? i realize this motor is not setup for it...but i would like to have the option to add a small amount of boost later on...i was thinking something like 9-10psi....enough to get me over the 500hp mark...i am looking at around 400rwhp right now...
Any ideas?
Thanks.
boosted_6.0L
04-22-2006, 03:39 PM
Any ideas?
Thanks.
That compression will limit you on how high of boost you can run. 10psi is doable though. Remember to have a good tune and fuel
NYSS Guy
04-22-2006, 07:41 PM
I have run 8 psi on the stock bottom end. But it has to be intercooled. On a forged bottom end, I would agree that 9-10 should be doable.
NHRA
04-25-2006, 07:37 PM
8psi is possible and will surely get you that 500 HP. You may want to swap a different cam in place of that LE3.
