Gmpp Head +cam Package
Old Apr 19, 2006 | 06:37 PM
pto039's Avatar
Question Gmpp Head +cam Package
Hi All I Have A Zo6 Head And Cam Package And Would Life Info On The Install And The Performance The Concern I Have Is. Will The D Shaped Ports Work With My Pacesetter Longtubes And Should I Go With Shaft Mounted Rocker Arms
Old Apr 19, 2006 | 09:21 PM
Greed4Speed's Avatar
Re: Gmpp Head +cam Package
They're LS6 heads and cam. Z06 is the C5 performance package. Thats like saying SS heads and cam when they're LS1 heads.
They should work with anything that'll bolt to an LS1. Stock rockers will be fine.
Old Apr 19, 2006 | 09:59 PM
CollinsAuto's Avatar
you'll be disapointed. the ls6 heads are decent but the cam leaves a ton of power on the plate. as for pysically installing the parts. No problem there. Might want to check pushrod length to be safe but otherwise should all just bolt together.
Old Apr 20, 2006 | 06:35 AM
teke184's Avatar
yeah the ls6 cam has a smaller base circle...so you need different length pushrods.
get those heads a mild port job and you'll get alot more power out if it.
Old Apr 20, 2006 | 11:36 AM
If they're LS6 heads they should have the longer stemmed LS6 valves....
Old Apr 20, 2006 | 03:42 PM
pto039's Avatar
thanks for the info
Old Apr 22, 2006 | 01:23 AM
Ken S's Avatar
is there a specific gmpp parts # for the ls6 heads and cam?
or did you buy the preassembled LS6 heads, that come with the ls6 vales, springs, etc.. and also get the ls6 cam?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Catmaigne
Dec 25, 2014 12:16 PM
Ken S
Jul 25, 2002 11:23 PM
