Anyone have there pulley bolt break on a P1-SC
wicked_95z
04-18-2006, 09:26 PM
After less than 10k miles my tensioner has gone to ****, so I was pulling off my blower and bracket to send to SDCE. And when I went to lower the blower out of the bracket the damn pulley fell off in my hand. I somehow managed to break the bolt off in the head unit. This happen to anyone else? I seem to have had nothing but bad luck with Procharger from the beginning and Im about ready to mail the whole thing back and go turbo.
quickmedic1
04-19-2006, 09:22 AM
I too lost a tensioner pulley at less than 10k. Most recently I blew the whole supercharger up in the driveway. Sent it back to procharger April 6th and it has been mia ever since. I am sorry I built my new motor for the supercharger. I dont think the p1sc should have blown up with only 10k miles. I dont even race the car. Its a weekend cruiser. So much for being the most reliable sc on the market.:mad:
markinkc69z
04-19-2006, 07:30 PM
If you broke the grade 8 bolt holding on the supercharger pulley you need to back off on the impact torque setting. It didn't just break on its own.
Blown SS
04-19-2006, 09:33 PM
The thing is, I have never touched that bolt. Never did a pulley swap and never had to retighten it
Willie
04-19-2006, 10:18 PM
....This happen to anyone else?
Amazing! In a distorted way, I'm glad to see this has happened to someone else. This happened on my D1SC when I owned it. Not once, not twice, but three times. After the second time, I shipped the head unit and both halves of both broken bolts back to ATI. They told me they had never seen, nor heard of this before.
I tried different torque values and bolts of differing strength -- Grade 5 and Grade 8. None of this mattered. I eventually broke a third bolt.... I then had a mechanical engineer at my employment examine the bolt. The fracture was due to torsional shear. Maybe an ME would be able to explain this in detail as I do not recall the details -- this happened about three years ago.
Other than the bolt issue, I've had very good results with the D1SC. Ran a sub-12 second pass at 117.62 mph with a 3,900 pound IROC-Z with a 305 TPI making 14-psig boost! But as my sig attests to, I did make a change....:D
wicked_95z
04-20-2006, 07:01 AM
Willie is your Iroc yellow??
Well Im getting ready to put a grade 8 in and if that doesnt work then Ill try 18-8 stainless, that is if I can get the old one out.
Willie
04-20-2006, 09:22 AM
Na, it's white. The following website is very outdated but it shows my setup when I was supercharged:
http://members.optushome.com.au/iroc-z/cars/willie_irocz/willies87.htm
I was able to remove the bolt by drilling a small hole through the center then using an EZ out. It came out in one piece with all three broken bolts.
Willie
wicked_95z
04-20-2006, 09:43 AM
Thats good news, that's what Im going to try tonight
Willie
04-20-2006, 10:28 AM
When I was having this problem, a friend of mine who works for Caterpillar, gave me a couple of Grade 8 bolts that are made by Cat. They are much better quality than your standard Grade 8 bolts. It was at this time that I sold my D1SC. I still have these bolts. I'd be glad to ship them to you at no cost. I also have a spec sheet that details why these bolts are better/stronger. If you'd like me to scan this and send it to you, e-mail me.
Willie
tplsz87@cox.net
30thTA0525
04-21-2006, 12:58 AM
was that pass on a stock 305 lower end??? and in Tucson on top of that?? thats very impressive especially if in tucson
