Re-fill?
"White Knight"
04-18-2006, 03:25 PM
Okay this will be my first summer on the juice. One problem I don't have any juice to use. Where can I get it?:D
I am trying to find a place that I can get my bottle filled. Anyone in Michigan on here that knows a place, I am like 30 minutes north of Lansing and 40 minutes from Mid-Michigan Motorplex--There has to be one around here, but I just don't know where.
I will probably just have to go to the track and ask around.
"White Knight"
04-18-2006, 03:27 PM
By the way how much a hit in the wallet to fill a ten pound bottle?
snod83
04-18-2006, 03:56 PM
I am not sure of a place for you, but its somewhere in the 4 bucks per pound range. I have paid 3.50-4.50 a pound.
Injuneer
04-18-2006, 04:32 PM
http://www.holley.com/dealers/NOSDealerLocator.asp
"White Knight"
04-19-2006, 02:06 AM
thanks:bow:
trymy6
04-20-2006, 10:33 AM
I've been paying 4 bucks per pound at the local JEGS store for the past few years. I used to have the hookup at a welding shop for $2 per pound, but my firend no longer works there. Not sure if there is a JEGS around you...
Brandon
WinSomeLoseNone
04-25-2006, 02:40 PM
WOW it is $6.00 a pound here is PA....i pay $60.00 to fill my 10lb tank... it tears your wallet up..
Edit*
WOW I went to that link on Holley and entered my info. Gave me a shop I didnt know existed, I called them and they said they fill for $4.00 a pound SWEET thats $40.00 a fill and $20.00 saved everytime !! THANKS
WOW ive wasted somewhere around $300.00 over the past few months!! YEA
jsetzer
04-25-2006, 03:31 PM
Wow, I thought $2.75 was high...
srsnow
04-25-2006, 05:27 PM
you can also call 1-800-99-refill which should be the same as the website version, not sure if they update them at the same time
camaro81
04-25-2006, 09:24 PM
$2.50 a pound here in Raleigh, NC :D cost me $26 to get mine refilled yesterday
93Phoenix
05-01-2006, 10:45 AM
How long does your N20 last on a 100 shot?
trymy6
05-01-2006, 11:56 AM
Depends how much you spray it, and how much bottle pressure you have when you do spray it. If the bottle is room temperature and you're spraying at 600-700 PSI , the shot will be weak but you will probably get 15-20 good shots out of it. If you have a warmer ,and spray it with 1000-1200PSI the shot will be strong but will not last as long. Too many variables to be able to say for sure how long it will last. And remember, nitrous is not like Maxwell House Coffee, it's not good to the last drop :) I usually refill my bottle when it gets down to about 4lbs left.
