94 camaro 94 caprice computer
percylhd
04-18-2006, 12:49 PM
I am working on a 94 Camaro with code 43 knock sensor and a bunch of abs codes. This camaro has a computer from a 94 caprice does anyone know if this computer is campatible with a 94 camaro?
Lt1Regal
04-18-2006, 09:35 PM
The PCM will work fine....but the caprice has 2 knock sensors. You should be able to swap your old Knock Module from the camaro to get rid of the Knock Code. If you dont have the old one get a Lt4 Module.
Good Luck
percylhd
04-19-2006, 05:57 PM
tried that have to get differnt computer
Dave89IROC
04-21-2006, 09:27 PM
the computer is the same f-body to b-body, only difference if the knock module and flash(software)
Injuneer
04-22-2006, 01:18 AM
The ABS codes aren't set by the PCM. They come from the EBCM. You don't need a new computer.
percylhd
04-23-2006, 07:17 PM
the abs has been repaired since the first post.It was traced to a wire at the connection above the LF wheel sensor.The code 43 knock sensor,was checked out according to the manual.Knock sesor is good so are wires,next is either connection at computer,or computer.The owner of the car insists on putting
in a new computer.Thanks for the info,you can e-mail me if you would like to know what the final fix is
