Blow down tube?
"White Knight"
04-17-2006, 11:26 AM
I need a blow down tube that i can easily more around and bend, basically I need to go down with it and then out an existing hole under the bottle. Can I just use normal bradied nitrous line with an attachment on the outside of the car to hold the end outside? Would this pass track inpection?
LB9GTA
04-17-2006, 01:36 PM
yes, nitrous line is strong enough.
I used hydraulic line, cheap and can handle the pressure.
"White Knight"
04-17-2006, 02:33 PM
Have you ever had it to the track, did it pass tech inspection? This is what I am mostly worried about.
Injuneer
04-17-2006, 11:15 PM
I use a braided -8AN line. Screws directly onto the relief valve, and connects to a bulkhead fitting on the floor of the hatch. No reason it wouldn't pass tech.
LB9GTA
04-17-2006, 11:27 PM
We only have 1/8th mile airport drags,(been to 3 so far with it)
We are not as serious and I passed every time
OBE1 95Z28
04-18-2006, 10:40 AM
The line won't see excessive pressures as it's open at one end.
"White Knight"
04-18-2006, 02:04 PM
I wasn't worried about the hose breaking, more of it being a very technical/picky at the track about it not being a solid tube so it doesn't flex.
Thanks guys
