loose Clutch fork
Old Apr 16, 2006 | 12:08 AM
Heatmaker's Avatar
Advanced Member
loose Clutch fork
Pulled out the slave cilinder to check and see why the pedal was vibrating so much. The clutch fork wiggles up and down rather loosly... even back and fourth it feels very loose... I don't remember the fork moving around so much... ideas?
Old Apr 16, 2006 | 01:29 AM
wrd1972's Avatar
Re: loose Clutch fork
The LT1 clutch fork is sloppy as hell, this is totally normal. Makes you wonder how the thing even works.
Sounds like you have another problem.
Old Apr 16, 2006 | 10:41 AM
Heatmaker's Avatar
Advanced Member
I no idea what's going on with this sucker... fulley beld hydraukics... adjustable master cyliner... new flywheel, and shimmed flywheel, and I still get vibration at around 1900rpms and in the pedal at idle
Old Apr 16, 2006 | 02:43 PM
Camaro97USAF's Avatar
What kind of clutch? Mine did the same thing about, and found out my center hub took a poop on me.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
