90tealindy
04-12-2006, 04:24 PM
I am wondering if anybody here has ever used touch up paint for their car? I did a little bit the other day and I tried to use rubbing compound to smooth it out and what not and I ended up slightly scratching my original paint. Could anybody tell me how I can avoid this or is it something that just happens?
jons69
04-12-2006, 05:07 PM
I hate rubbing compound! I have tried it several times and always came out with the same result......more scratches!
95LT1conv
04-12-2006, 09:53 PM
there are several other steps to follow after using rubbing compound. it is abrasive so of course it is going to scratch. nothing a good polishing wont cure
teke184
04-13-2006, 09:29 AM
don't you use polishing compound AFTER the rubbing? polishing is basically replacing small scratches with SMALLER scratches.
i had a TON of small scratches in my paint from a palm tree that was battered against my car in a hurricane last year. few hours of rubbing and they are 75% gone...at least from more than 2ft away.
you could also try some 2000 grit wet sand paper, then rubbing, then polishing
been wanting to try that, but i wanna test it on a "junk" car first. ii've got 2 or 3 chips in my hood that i'd like to get rid of
