gillt1
04-12-2006, 07:27 AM
Hi, Just purchased a 1996 z28 , what's difference between obdI and obdII, Thanks for any insight
obd I obd IIgillt1 04-12-2006, 07:27 AM Hi, Just purchased a 1996 z28 , what's difference between obdI and obdII, Thanks for any insight Injuneer 04-12-2006, 09:03 AM Basically, OBD-II adds a bunch of diagnostics to catch emissions problems... -misfire detection using a crank sensor, including misfire counts by cylinder -after-cat O2 sensors to measure if the cats are there and working -O2 sensor response/switching test -tests to verify AIR system is operating -EVAP system flow/no flow detection -MAF rationality test, frequency range check -coolant time to closed loop -more sensitive EGR flow verification -idle speed test -traction control excessive time on -standardized nomenclature across brands -standardized 16-pin ALDL connector Most of the control strategies.... e.g. A/F ratio control.... are the same. Apparently some differences in the A4 shift logic that allows higher stall convertors. | ||
