Gun5
04-12-2006, 02:05 AM
My Driver one is slow as **** but still works but when I flip it left the passenger one won't move at all and I cant move it manually.. help??? :mad: im gonna end up going over blind and hitting someone i know it
Power Mirror Not Working??Gun5 04-12-2006, 02:05 AM My Driver one is slow as **** but still works but when I flip it left the passenger one won't move at all and I cant move it manually.. help??? :mad: im gonna end up going over blind and hitting someone i know it Rashiki 04-12-2006, 02:43 AM How old is the car? If you can't even move them manually, sounds like the motor has just plain siezed and will need to be replaced. Gun5 04-13-2006, 01:51 AM How old is the car? If you can't even move them manually, sounds like the motor has just plain siezed and will need to be replaced. its a 94 WHITE94Z28 04-13-2006, 06:17 PM Yes this happened to mine too. The pass side was stuck moving in one direction. I think it the mirror would move up/down but not in/out. I popped the mirror out and found some swivels and there were some small motors and gear as well. I managed to get the seized motor freed and it's been working since. Gun5 04-15-2006, 01:57 AM Yes this happened to mine too. The pass side was stuck moving in one direction. I think it the mirror would move up/down but not in/out. I popped the mirror out and found some swivels and there were some small motors and gear as well. I managed to get the seized motor freed and it's been working since. how do u go about popping the mirror out? Rashiki 04-15-2006, 04:20 AM I believe you have to take the mirror off from the inside of the car, then undo the harness on the inside of the motor, and the mirror should pop off with the motor attatched. | ||
