Fuel pump?
TRIPOWER
04-05-2006, 11:08 AM
what's a good replacement pump? stk is a 190lph is a 255lph to much? im not making crazy hp but just bolt on's and a hot cam. can i just get a pump or do i need the harness?
Z28SORR
04-05-2006, 11:27 AM
If you haven't changed the fuel system, bigger line, pickup, etc. And/or your not having pressure problems, why do you need a new pump? Check your fuel pressure at WOT under load.
TRIPOWER
04-05-2006, 11:49 AM
The reason is the car has over 100k and just looking for an upgrade
2000GTP
04-05-2006, 04:48 PM
The Racetronix pump is a cheap upgrade and is rated at 255lph. You can get them for around 125 bucks.
BadgeZ28
04-05-2006, 08:39 PM
I am using a Walbro 255 pump. It requires minor adapting and emits a audible operating noise in my car.
