95_z28_4_Ivan
04-04-2006, 03:26 PM
Sometimes When I Turn Off The Engine And Step Out Of The Car, The Radio Remains On, So I Have To Go Back And Play With The Key Til It Turns Off The Radio.
Any Suggestion On How To Fix The Problem?
Ivan.
Injuneer
04-04-2006, 05:34 PM
Could be your key switch is worn and its stopping somewhere between the "accessory" and "off" positions, and letting you remove the key - leaving the switch in the "accessory" position. Or there might be a problem with the retained accessory power (RAP) module that provides power to the radio and windows for 10 minutes or until you open a door.
95_z28_4_Ivan
04-05-2006, 04:44 PM
fi the switch is worn out, what can I do to fix it??? just replace it ?? or is there more toit ? how do I remove it?
thanks 4 the help!
