Which stock cd players fit??
Mushijobah
04-04-2006, 03:36 AM
I have a 96' camaro and am wishing to replace the stock tape player with a stock cd player. Well, it doesnt have to be exactly from a camaro, but I want the same model cd player in or a compatable GM unit (to avoid breakins). I found a few Delco Loc-II's from cavaliers but do not know if they will fit in mine. Also, do any of the monsoon ones fit? Thanks guys.
Mushijobah
04-04-2006, 12:07 PM
PLEASE GUYS?? Does anyone know?
valter
04-04-2006, 12:27 PM
Check what type of player do you have now. Monsoon require additional amp on the back. For Bose, there amps in each speacker. They are not interchangeable. You may try to post it in "Car audio and electronics" forum. But why do you want stock??? :confused:
Mushijobah
04-04-2006, 03:03 PM
That is why. The ones from cavaliers look exactly like ones coming stock in the camaro. I need to know if it will work.
midnightblackZ
04-08-2006, 09:54 AM
Check what type of player do you have now. Monsoon require additional amp on the back. For Bose, there amps in each speacker. They are not interchangeable. You may try to post it in "Car audio and electronics" [/B[B]]forum. But why do you want stock??? :confused:
Silly Wabbit!
midnightblackZ
04-08-2006, 09:57 AM
Check what type of player do you have now. Monsoon require additional amp on the back. For Bose, there amps in each speacker. They are not interchangeable. You may try to post it in ]"Car audio and electronics" [/B]forum. But why do you want stock??? :confused:
Silly Wabbit! :rolleyes:
midnightblackZ
04-08-2006, 09:59 AM
Ooops... Silly ME:eek:
FastZinTennessee
04-08-2006, 11:28 AM
If you have a Monsoon deck you will need to replace it with a Monsoon unit. If you have a Bose deck you will need to replace it with a Bose unit. If it says neither, you will need to replace it with one that says neither!
Generally, your run of the mill headunit is the same size as the rest of the headunits of that year, they do use the same harness and antenna plug. Really the variance is usually cosmetic. Most of the actual chassis of these head units are the same, you can just swap brackets from your headunit that came out of the Camaro to whatever you buy and bolt it in.
Stay away from Caddillac headunits, they are usually amp'd in some weird way and often times use a different harness- same goes for Oldsmobile.
Before you buy that one out of a Cavalier, take your Camaro headunit, and eyeball the bracket mounting provisions on each and make sure they match.
