Musclehead87 04-01-2006, 03:55 PM Hey guys. I'm leaning towards an 98-02 SS. Just need some advice first.
Let's say the SS is BONE STOCK. What RWHP should i be expecting with these mods..
1. SLP cold air intake
2. SLP loud mouth 1
3. Y pipe off road
4. Headers (anybody know a good make for them?)
thanks guys :)
camaro_five0 04-01-2006, 04:35 PM well the 98-01 SS has the LS1 intake, while the 02 SS came stock with the LS6 intake. This adds a little HP. I dont know how much but is is a difference. With those bolt-ons you're PROBABLY looking at 340-350 HP (in an 02).
Musclehead87 04-01-2006, 05:13 PM well the 98-01 SS has the LS1 intake, while the 02 SS came stock with the LS6 intake. This adds a little HP. I dont know how much but is is a difference. With those bolt-ons you're PROBABLY looking at 340-350 HP (in an 02).
damn that's pretty good. thanks a lot man
GhostZ28 04-01-2006, 07:57 PM more like 340 ish, or lower. you're very capable of much more (360), with a good tune.
99+ have bigger injectors, 99's have the biggest cam, and some 01-02 came with LS6 blocks! your choice. the newer versions also have basicaly shorty header exhaust manifolds. LS1=LS1 some naturally dyno higher, some lower. the deciding factor should be what the best deal is and whats been best cared for.
SSpdDmon 04-01-2006, 08:32 PM Whoa guys...knowledge base is slipping in this thread. 99's had the smaller injectors (26#ers), 01's had the LS6 intake too (not just 02's) and true some of the last f-bodies came with an LS6 block...but that won't improve performance.
If you get an M6 with those mods, then you're looking at mid 340's for rwhp. A tune could net you another 10hp or so. An auto will drop you 10hp or so....but they are great when you add an aftermarket converter. I expect mid to low 12's with the mods you've listed plus a converter/gears, which isn't bad at all considering the car went ~13.3 bone stock. :)
cbrakllr88 04-01-2006, 08:58 PM They started putting the LS6 intake on 2001 and up.
MonkeyBoneSS 04-01-2006, 09:57 PM i was under the beliefe that only a few SS or Z28's had the LS6 in them. They were put in there by mistake, so they claim!!
AL SS590 M6 04-02-2006, 08:53 AM i was under the beliefe that only a few SS or Z28's had the LS6 in them. They were put in there by mistake, so they claim!!
LS6 BLOCK not LS6 motor and it wan't by mistake.
Musclehead87 04-02-2006, 09:23 AM wow. nice numbers. thanks a bunch guys! :)
GhostZ28 04-03-2006, 01:10 AM ya i couldnt remember the injector sizes, i thought the 99 and up years had bigger ones, but i figured someone would correct me!
scottslt1z28 04-03-2006, 08:05 AM more like 340 ish, or lower. you're very capable of much more (360), with a good tune.
wow knowledge is slipping..............as stated earlier........99's had the smallest injectors
98's had the LARGEST injectors and the MOST Aggresive cam of all the years. Yet the later versions 01-02 made more power simply because of the ls6 intake manifold and the ls6 exhaust manifolds.
The block has no real significance in power. There were a few other things that distinguish the 98 f-bodies from the 99-00 and 01-02, however i noted the large ones above. Search and find out which year/car is better for what you want to do.
--Scott
Musclehead87 04-03-2006, 11:18 AM wow knowledge is slipping..............as stated earlier........99's had the smallest injectors
--Scott
yeah i am doing some research. And you guys are helping me a lot to. I really do appeciate it and all. What i plan doing to my next car is running it on all motor.. possibly no forced induction, ever. haha. So, i'm deciding on what camaro ss (98-02) that would provide good power and will respond the best to mods. I'll check out the 98 about the huge cams and big injectors. THanks guys
cabell84 04-03-2006, 12:09 PM I'll check out the 98 about the huge cams and big injectors. THanks guys
Don't get the wrong idea, the cam is hot HUGE by any means, just a little more agressive, same goes for the injectors.
NiteRider 04-03-2006, 12:56 PM wow knowledge is slipping..............as stated earlier........99's had the smallest injectors
--Scott
2000's had improved exh manifolds as well.
GhostZ28 04-04-2006, 01:05 AM i was PRETTY sure the 99's had the slightly larger cam, i remember because i was excited i picked the year with it. I jsut tried to search for the tread from about a month or 2 ago that was alot about this stuff, and cant find it. does anyone have a link to it.
AL SS590 M6 04-04-2006, 01:12 AM wow knowledge is slipping
--Scott
Yes it is.
the 98s and 01-02 have the same injectors.
the 00-02 have the same exhaust manifolds
the 01 and 02 have LS6 intakes and no EGR But that's not the only reason that they're a little stronger. They also have the revised LS1 241 head castings.
scottslt1z28 04-04-2006, 01:18 AM i was PRETTY sure the 99's had the slightly larger cam, i remember because i was excited i picked the year with it. I jsut tried to search for the tread from about a month or 2 ago that was alot about this stuff, and cant find it. does anyone have a link to it.
the 98's lift is slightly larger than the rest of the years...........if i find the thread i will link it for you
GhostZ28 04-04-2006, 03:51 PM if i find the thread i will link it for you
that'd be awesome. useful info on that thread. i should've bookmarked it.
