GMCAMARO
04-01-2006, 03:43 PM
I replaced the 10 Bolt over the winter with Moser 12 Bolt. I took the car out for the first time on Thursday and again on Friday. I was surprised by how many rattles there where. Especially over bumps, they appeared to be coming from the rear end. I ensured everything was tight. Any suggestions?
96speed
04-01-2006, 11:18 PM
Check, recheck, and check the torque arm bolts again. They are prone to loosening!!!
I should have gone with a strange OR 9" :mad:.
Ryan
xxsaint69x
04-02-2006, 12:44 PM
Ryan
you guys need to learn to how to tighten stuff propertly, i never have any problems with mine coming loose on my Moser. But then i use a big pipe on the end of the rachet and planty of red loctite. :)
Injuneer
04-02-2006, 03:33 PM
Also need to post in the correct forum :) . This doesn't belong in Advanced Tech...... moving to Drivetrain.
StudyTime
04-02-2006, 05:21 PM
Oh, the irony. We need to learn to tighten properly? :D
If you're rattling when you go over bumps make sure your rear anti-sway bar is not interfering with the cover on your 12-bolt. Look for shiny spots on the cover or the bar.
Ben T.
96speed
04-03-2006, 06:31 PM
Funny, I thought lock washers, loctite, and about 90 Ft-lbs would help me beat the documented problem by multiple other Moser owners. I must be using the wrong end of the wrench! ;)
Ryan
