Driver side window dies after 2 seconds of use!
Boomer_Z/28
03-30-2006, 09:08 PM
I have a 99 Z/28. The window just started to act up. It stops about an inch and a half open. Have to wait a bit just to move it half that. The passenger side window works just fine. No problems. Now I did finally replace all the speakers in my car and a new cd player, and I notice it got worse the farther I went.
Is it loose connection? Or are the speakers soaking up too much power? How bout the altenator? Head lights dim now and then. I havent a clue about this! Help would be nice!
stroked383z28
03-30-2006, 10:14 PM
Your window motor is on its way out and needs to be replaced.
VTsullyman
03-31-2006, 02:22 PM
Yeah its not your speakers or anythign else liek that. The motor is on its way out. The only thing u can do other than replace it is to adjust it. Sometimes it gets out of line and then takes alot more work to move it. There was a thread somewhere about how to adjust them.
97FormulaWS-6
03-31-2006, 03:22 PM
Yup, your thermal Circuit Breaker is shot in the Window Motor; best bet is to just replace the motor.
If you want you can search in the General or LT1 forum about the Thermal Circuit Breaker bypass modification.
