QA1 shocks question.
94NDTA
03-30-2006, 06:27 PM
I have adjustable QA1's front and back.
What is the best set up for the strip for these? Do I want at harder setting for the rear and a softer setting for the front?
What is recomended?
DarkHorse
03-30-2006, 07:46 PM
To be quite honest every setup will be different. It's best to make a couple of passes then make a change, couple of passes, take notes, repeat process.....
Track conditions, vehicle setup, temp, etc.... will all play a factor. Sure you can get someone elses setup info but don't be surprised if it doesn't apply to your car.
shady93z
03-31-2006, 12:54 AM
i always started with 0-2 up front and 4-5 out back.
Injuneer
03-31-2006, 10:53 AM
Ditto.... turn the fronts to "1" to start, and leave the backs at "6". Try a pass or two. Then try moving them a step or two at a time until you find the sweet spot.
94NDTA
03-31-2006, 10:51 PM
Thanks guys.
