JP85Iroc
03-30-2006, 12:07 AM
I know I will need the bracket and TV cable from a 93 Z28..will I need anything else? Is there a provision to attach the TV cable to the throttlebody or will I have to change throttlebody.?
what will i need for a 700R4(92 model)install in 94 Z28JP85Iroc 03-30-2006, 12:07 AM I know I will need the bracket and TV cable from a 93 Z28..will I need anything else? Is there a provision to attach the TV cable to the throttlebody or will I have to change throttlebody.? Thanks Digital Designs 03-30-2006, 09:27 AM you will need a 93' z28 TB and your pcm retuned. JP85Iroc 03-30-2006, 10:48 PM why would you need the pcm retuned....just so the SES light doesn't come on? It shouldn't affect the way it runs...should it? Digital Designs 03-30-2006, 10:56 PM precisely, also, make sure the transmission is set up for a electric speedometer and i think you will need a 93+ 4l60e tailshaft housing for the torque arm. | ||
