Plague
03-29-2006, 08:43 PM
Like the title says, how do you know they are worn? Also, who sells them and does anyone have a guide to know how to change them?
In first gear, I don't have to get it on it hard at all and the shifter will move about an inch to the right. How do I check from under the car?
teke184
03-30-2006, 07:25 AM
no way to really "check"....
if the engine moves that much...they could use to be replaced.
most of the vendors sell the mounts, just look for the prothan products. i think i got mine from BMR.
the installation is pretty straight forward, the hard part it getting the mounts out from the engine bay. it's a VERY cramped space. other than that its 4 bolts on the cross member, and 4 on the block.
my engine barely moves 1/4" in the engine bay under load with the mounts.
snake_skinner93
04-02-2006, 06:28 PM
if you have a lot of vibration at idle, is a good way to know your mounts are bad. i bought a replacement set of poly mounts from WS6Store.com for like $50 ... havent put them in yet. gonna do headers and put them in while the manifolds are off this week.
