need some launch suggestions?
blackztpi
03-28-2006, 11:11 PM
i'm going to pilot a 6 spd head/cam car with 3.73's in a stock 10 bolt. the runs will be made for trap speeds mostly, but i don't want to go out there and run 14.5@114. any launch suggestions for stock tires and a 10 bolt with the 6 speed? i've never driven anything i have to pamper off the line like i will this one. any tips for getting going while keeping 60's in the 2.0 range?
Bow94z
03-29-2006, 12:11 AM
Um drag radials...then prolly slip the clutch from 2k
TQdrivenws6
03-29-2006, 07:27 AM
If you are on a true street tire, just do what you can to stop spinning. If you are on MT DR's then I would say a 3000-4000rpm quick slip but preload the drivetrain at the second yellow.
