89_Irocz
03-28-2006, 05:56 PM
Does anyone what the specs are for the stock 89 L98 heads? And whats the most HP you can get and still use the stock heads?
L98 Heads89_Irocz 03-28-2006, 05:56 PM Does anyone what the specs are for the stock 89 L98 heads? And whats the most HP you can get and still use the stock heads? LesPaulGoth 03-28-2006, 11:29 PM Valves: 1.94 intake 1.5 exhaust Combustion Chamber: 58cc (Aluminum Vette Heads) 64cc (Iron Camaro, 'Bird, TA heads) Flow #'s (int/exhaust) - These are the 58cc Vette Numbers, they should be very close in the ballpark, if not the exact same. 0.1" lift 55/52 0.2" lift 120/104 0.3" lift 160/133 0.4" lift 186/151 0.5" lift 196/170 Not sure on the runner volumes, but its probably not that impressive. Trickflow had a match against Vette L98 heads and flowed 40hp better. At the time, the L98 was making 420hp. So I guess you could get that high, but it would be tough, and you'd have alot of porting to do. Honestly, I would just get new heads. Trickflow's 23 degree aluminum heads are $1145.95, which is a pretty good deal. 91Z-28 03-29-2006, 01:30 AM 163cc intake runner. 91Z-28 03-29-2006, 01:32 AM http://purplesagetradingpost.com/sumner/techinfo/heads1.html http://chevyhiperformance.com/techarticles/41598/ | ||
