4SFEDZ
03-28-2006, 02:06 PM
i am looking for the thinnest lca so i can space them towards the inside of the car for additional tire clearence, but they have to be strong as well, what do yall recomend???
who makes the thinnest lca's??? for tire clearence?4SFEDZ 03-28-2006, 02:06 PM i am looking for the thinnest lca so i can space them towards the inside of the car for additional tire clearence, but they have to be strong as well, what do yall recomend??? MPB70350 03-28-2006, 03:53 PM I went to colman racing and picked up threaded aluminum lca's from them and put QA1 rod ends in them they are extremely light very thin for clearance and i spoke with a a guy that has been running them for some time and claims they are stong enough to run a .5 60 foot time (no that is not a typo) I also have the same set up for my PHB. My friend also has them on his tubed twin turbo small block and they are doing just fine. I can get you the exact sizes and spacer size if you need them. 4SFEDZ 03-28-2006, 05:58 PM that would be awsome cause i am looking at doing this project very soon but wasnt sure where to start hotpart 03-28-2006, 08:33 PM This is what we have offer. http://www.hotpart.com/index.php?p=show&id=146 MPB70350 03-29-2006, 08:48 AM Those ones that hotparts has look good as long as they are quality rod ends, if not they will wear out really fast on the street. QA1 road ends are 30 a piece from jegs so making your own will cost about 175. This is the guy that i got the idea from check out his site. http://www.jonaadland.com/Z28/Z28/Z28.html this is the direct link that explains exactly what you need and how to do it, its really easy http://www.jonaadland.com/Z28/Mods/LCA/AluminumLCAs.html Let me know if you have any other questions hotpart 03-29-2006, 10:21 AM We quite using the QA1 Product when they moved manufacturing to China. There quality control has gone down hill drastically. Our rod ends are a 3 piece very high precision teflon lined rod end which we found outlast all of the QA1 products we have ever used. 4SFEDZ 03-29-2006, 12:51 PM Those ones that hotparts has look good as long as they are quality rod ends, if not they will wear out really fast on the street. QA1 road ends are 30 a piece from jegs so making your own will cost about 175. This is the guy that i got the idea from check out his site. http://www.jonaadland.com/Z28/Z28/Z28.html this is the direct link that explains exactly what you need and how to do it, its really easy http://www.jonaadland.com/Z28/Mods/LCA/AluminumLCAs.html Let me know if you have any other questions thanks bro 4SFEDZ 03-29-2006, 12:52 PM This is what we have offer. http://www.hotpart.com/index.php?p=show&id=146 is the rod that goes through the eye movable or is it fixed? hotpart 03-29-2006, 02:07 PM Are you referring to the reducer bushings? If you are they are fixed. | ||
