6 cylinde rebuilder (drum to disc conversion)
Heatmaker
03-26-2006, 12:17 PM
Im despirate, and after 4 days of no answer in the drivetrain forum... lwets see if the guru's in here can help.
ok... so I need a fresh new 10bolt.... and I went down to the lockal junk yard... all they had was 1 F-body. luckily they had that atleast. It's a 94 6cilinder, but it has a clean rear, with ABS. Only problem is it's a drum and not disk... so I'm thinking of taking the rear of the 6cylinder I found, and throwing in new gears and differential... takign that disc junk off, and tossing on my disc brakes from my 95 Z28... does anyone see a problem with this? BTW how much does a rear axle with out the tires or brakes weigh?
MachinistOne
03-26-2006, 01:24 PM
Why not rebuild yours?
Injuneer
03-26-2006, 01:56 PM
PLEASE post on the correct forum.
Helpful Hint - You might want to use more accurate "topic" to get responses. "6 cylinde rebuilder" isn't likely to draw the attention of people who might be able to answer a question about converting from drums to discs.
Did you verify the 6 cyl rear had Posi? Most of them don't.
Heatmaker
03-26-2006, 04:56 PM
Thanks,
I haven't verified if it was posi or not... would that make a difference if I'm goig to swap out differentials?
The reasdon I want to put on a different 10 is that the one on my car isn't the original either, and after swapping out the components it stell seems to be giving me trouble.
RE AND CHERYL
03-26-2006, 05:17 PM
I wouldn't buy the junk yard rear just to install all the components from your rear on it. Wouldn't you just end up with you rear with a dirrerent housing.
The V6 cars almost never had posi. A drum brake car is sure not to.
Re'
