91 Camaro RS
03-22-2006, 05:03 PM
I've been thinking about saving up for this suspenson setup since for starters I can get it for about $650 (front and rear) and it'd be nice to get my car to handle better than it already does. To anyone else who has this setup on their 3rd gen, how do you like it and how much did it improve the handling? Does it lower the car any from the stock position and if so, how much? How long would it take to install the entire setup in my driveway?
kandied91z
01-05-2007, 01:38 AM
searching probably would have helped you with this.
their typical thirdgen setup should run you around 1500-2k in parts alone. you can save money elsewhere by going with analog gauges and cheaper valves but i wouldn't recommend it.
the kit works great and is well worth the money. i'm running a custom system build by ART that i took the car too them for. the front air struts (similar to a coilover) were $1,200 for the pair alone. very similar in design to the 4thgen shockwave setup.
the rears use the coolride identical to the 4thgen rear setup. while this is an old thread if you haven't done it yet you should as it's a great modification.
