bringBackCamaro
03-22-2006, 04:55 PM
Where is the redline on an LT1 M6
Ive been shifting at 5,000 rpm
but i think its killing my times
how high should i be shifting
~5,200 ?
Sean94Z
03-22-2006, 06:47 PM
Isn't there a redline on your Tach? Try 5800 and see how that works ..
96flame
03-22-2006, 07:13 PM
I beleive the stock rev limiter is at 5800 rpms. I shifted at 5600 when the car was stock. Also remember the dash tach isn't very accurate. I hooked up a shift light for more accurate shift rpms.
bringBackCamaro
03-23-2006, 10:36 AM
is there such thing as a shift light that you dont have to also install a tach for? I dont run a MSD or anything like that
2000slp2768
03-26-2006, 06:44 AM
several companys make stand alone shift lights. MSD for example has 2; one has a dial on the back you set for the shift point, the other uses their rpm pills.
BradcTA
04-01-2006, 12:14 PM
At the track I ran mine up to 6200 a couple of times. I had LTs/TD so it still pulled hard up there...
LT1Squirrel
04-01-2006, 06:46 PM
i run first out to 6k and every shift at 58-59 after that by way of stock tach
