ruSSty
03-19-2006, 08:05 PM
well its a tbi motor the f/i system with the 2 injectors. well the car didnt want to start today i had cleaned the engine bay . i changed module,plugs,cables,air & fuel filter did an oil change.i go to crank it over and it wont kick on it just turns over it didnt want to start but did turn over.
finaly i noticed there was no fuel coming from the injectors when the motor would turn over.i disconnected feed line and checked for pressure and sure enough there WAS....
then i went in the cabin to check the fuses and noticed the inj. fuse in the fuse box had popped replaced it with another 10 amp fuse. then i got to start car it turns ON BUT IT WONT ACCEL...
i then noticed there was only fuel spraying out of the pass side injector and absouletly nothing coming from the driver side one. the car stays running perfect at idle but then when you rev the motor still no fuel comes out of the driver side injector. the motor takes a while to rev and then backfires when i rev it high and let go....
on one occasion the driver side injector bowl filled all the way to the top with fuel, but since the first crank it has nt sprayed nothing.
guys i need help here...
