goosechevy21
03-16-2006, 07:29 PM
I just rebuilt my L98 350 and found a new 700R4 for my 89 Camaro. I've got a Holley Street Dominator manifold on top (squarebore) and am looking to buy a new 600CFM Edelbrock for the simplicity and reliablilty.
My question is: which corrector lever and throttle cable/TV cable bracket do I need? I looked up the parts on Summit and they look about right, but I'd feel better asking someone who has a similar setup what they have. Right now, I'm looking at EDL-8036 and SUM-700203. Will these work for me?
carbed91TA
03-16-2006, 08:15 PM
I'm still in the process of converting from TPI to carb. One place ive been putting a lot of thought into trying is bowtieoverdrives.com. Little more expensive than summits but i like the design more.
Tru2Chevy
03-17-2006, 12:52 PM
Not a fan of the way the edelbrock carbs perform. I just bought a Holley 750 DP to replace my old Q-jet. A Holley 650 vac. secondary carb would be pretty good for your application.
- Justin
goosechevy21
03-18-2006, 12:09 PM
I already have a Holley 650 VS, but I need a spreadbore to squarebore adapter to use it. Had I done my research before I bought an intake, I wouldn't have this problem. I realize it's not a problem to get an adapter plate, but I'm not very confident with tuning a carb, so I'd rather just get one that's good to go out of the box and doesn't need adjusting frequently like Holleys apparently do.
I know someone on this board must have a similar combo on their car. Edelbrock carb with 700R4 behind an SBC. What did you have to do to make the 700 shift properly? i.e. bracketry and/or geometry corrector?
five7kid
03-18-2006, 02:39 PM
I already have a Holley 650 VS, but I need a spreadbore to squarebore adapter to use it. Had I done my research before I bought an intake, I wouldn't have this problem. I realize it's not a problem to get an adapter plate, but I'm not very confident with tuning a carb, so I'd rather just get one that's good to go out of the box and doesn't need adjusting frequently like Holleys apparently do.I don't know what you mean by that. Both the Holley and Edelbrock are squarebore.
Holley's don't need frequent adjusting.
NastyTA
03-18-2006, 03:03 PM
Not to mention the Edelbrock will need some tuning out of the box too. It will be close, but so would a Holley. No carb will be perfect out of the box.
goosechevy21
03-19-2006, 09:22 PM
Thank you so very much for your input. The amount of help you provided is so little that I consider it negative.
I present to you: Holley 650 spreadbore style
http://www.holley.com/data/products/pictures/medium0-80555C.jpg
link to actual page: http://www.holley.com/0-80555C.asp
All I wanted to know was which bracket and/or geometry corrector to use with the 700 and Edelbrock 600 cfm squarebore. I don't really care what anyone else's opinion on either Holley or Edelbrock carbs is.
Rice Killer87
03-20-2006, 10:39 AM
They will work,I like that summit brand one better.
